Sproulesxrunner
- May 11, 2010
- 3,278
- 2
Hey guys,
My S/C finally was installed but the boost is way too low. I have the URD 2.825" pulley on it and the S/C was only producing 3-5 lbs of boost. I know I am at a high elevation but that is ridiculous. The shop tested the S/C with a smoke tester and there was no leaks internally. The by pass valve is also works.
What the hell is going wrong?
Thanks
***EDIT***
It turned out not to be a problem. The issue was a combination of altitude (2.5 -2.7 psi loss), 20" winter tires with blizzaks (8-12% power loss), ECU hasn't "learned", and a really, really tough dyno.
Thanks
***EDIT***
