TTC Bracket not flush on Composite Leafs
05 X
I just finished the install of the Composite Leafs with the TTC Traction Bars using the modified brackets and even though the TTC brackets are tight and flush under the axle and U-bolts, the forward part on the brackets are not flush up to the Composite leafs on both leafs. The brackets were installed new and are not bent.
Does anyone know if this is normal or if modified brackets have been made available?
Are those pics when the truck is jacked up??
I really wouldn't worry about it because the brackets are strait.
LOW AND BLOWN
Ya I'm no Genious here but the gap does not seem right...But I guess there should be some gap to allow travel clearance there:hmmmm2:
the actual bar is too long. either scew in the other end in all the way, or you will need to cut it to shorten it
i was confused on what that pick was of, ignore my statment lol
05 X
Right, since the brackets have stayed straight, I'm not too worried. Just wondering if others with same set up have the same gap.
blastap
my ttc brackets are bent to shit so yours look awesome compared to how mine were.
