i think 99% of the time people blow the motor it's blamed on internals or heat, but the real culprit is most often the tuner
Lol because they decided to run too much boost which caused too much stress and/or heat?
I remeber reading a story about some Factory Racing team that was building an inline 4 for import drag racing.
I want to say it was Chevrolet. Doing their Cobalt Drag Racing car. Anyways.
They said in order to find the weak links in the system, they did NOS and kept adding more till something blew, once they were throwing a 300 Shot through it they where still running Stock Rods, Crank, and Block. Then they went to a Turbo, went through some more parts. Then back to the NOS.
In the end they ran off the Shelf Parts with the Stock Block and were getting in the range of 700 HP.
But really, this is kind of an odd question. Because all 3 are equally capable of making the same amount of power. The only problem is engnering.
With the Turbo it's pretty easy to go to a larger Turbo as you have a lot of options. The S/C could make just as much power if you had more options for them. As it stands right now (and I could be wrong) we have 2 options. URD and TRD. Both are ment for a rather streetable truck. We don't have anything like a 8-71 or 10-71 blower for our trucks like the Classic V-8 guys do.
And well NOS, it's just about building a proper delivery system. I've seen 500 Shot systems on Drag Cars. NOS is just so hard because it's literally so explosive. While at least with the Turbo and S/C it comes on rather gradually.
But just because something makes a ton of power doesn't mean it will suit your needs.
Yes, a S/C will have a small amount of parasitic loss at the start of the Powerband. But if you are Autocrossing this isn't an issue, because you stay in the upper part of the powerband throughout the race.
A Turbo does not have this loss, but it's also not as linear. You have Turbo Lag which means for a period of time you are not making any extra power, and need to build up exaust flow to build boost.
Well, NOS while it can make a ton of Power. It only lasts for as much NOS as you're willing to drag around.
Don't forget also, that a big Turbo takes a long time to spool. So while you might see big numbers. It's going to take you forver to get there.
Look at those 1,400 HP Supras. They make huge power but are turds at the strip and on the Road Course. Simply because it takes soooo long to build that power.
