Here would be the Ultimate Tacoma 4.0 modification using current parts and some customizing.
Performance Upgrades:
- URD Super charger system
- Larger front mounted inter cooler
- Custom under drive pulleys for - Water pump & power Steering - Alternator only if you do not want to run ICE modifications.
- JBA header to custom exhaust into 1 pair of 100 cel cats - if not caring about smog go to the long tube headers with no cats
- TRD muffler
- Larger 2/3 core aluminum radiator
- Electric fan - removes persite drag of the mechanical one (yes I know it has a clutch but still frees up hp when removed =p
- Larger oil cooler
Exterior upgrades
- Install the X runner kit - Reduces aerodynamic drag
- Bed cover
- Short antenna
Wheels, tires, suspension, brakes:
- Stopteck front break kit
- Large front sways
- Rear sways
- 18 inch ASA rims (only 23lb a rim vs 29 stock)
- 255, 55, 18 tires, (dealers choice for application)
- Stiffer shocks - once the stock ones are dead
- SOS rear disc conversion - Brembo roters with hawk pads
- Stainless steel lines
- ATB super blue / gold
That is all I can think of right now. Problem is all of the parts listed are either available or you need to custom apply them.
- TRD muffler
- Larger oil cooler
Exterior upgrades
- Bed cover
- Short antenna
- Large front sways
- Rear sways
