Viking Coilovers?
Not the best photo but hopefully you get the idea. This mount is for 6 lug suspension. From the photo the attachment / mounting bolts thread in from the top.
He's making a top hat that will accept the rod end....
easts1d3
I suggest you look at coilovers for 6 lug trucks. "I" understand the only difference is the spacing of the attachment bolts. ¯\_(ツ)_/¯
It will be very similar to that top hat!
easts1d3
I’d be interested depending on pricepoint. What size through bolt will you be using? 1/2” or 5/8”?
It will be whatever internal diameter the rod end of the for the shop will be
easts1d3
Ryan Robinson
Just finished welding brackets, painted with 316 stainless steel paint for rust protection..
AZ Sun Lover
Well finally they are at powder coating‼️
The photo is the office of AZ Powder Coating.
So who’s interested in a set? Sorry to say, one set is mine the other two are up for bid.
*Edit* they will be powder coated satin black.
AZ
Chris Griteman
So I saw this on Facebook and thought I would share it. If you having trouble getting a top mount made this might be a solution for you.
This is a Viking c211r shock with a 12" spring, using the stock top hats.
How does the lower mounting point on the viking shocks look once they are mounted?(it looks a little thin compared to oe)
