gixxerman11
Guest
but u proley had a fan i didnt the out side temp was 85
SignUp Now!Congrats Matt!
Now Yardie is the slowest in the VAB crew again...:aetsch:
You might wanna do a little more research before you go running your mouth. The slowest X is definately not a RR and gixxer has a few more ponies and a lot more torque to catch up to me :biggrin:.
No mouth running here...I was making a statement...:top: Its OK buddy, you're still my #1!!
You're the fatsest RR in my book schnukems....:2in1::tongue:
Congrats Matt!
For what it's worth gixxerman's numbers are legit. I had to shuttle the handicap to pick up his truck. While I was there I got my truck dyno'd as well. I didn't have the hp like gixxerman, but I found out my AFR, since my AFR gauge is jacked!!! Plus, I'm running the Volant cold air with ram air scoop.
I running rich as hell 4,000 rpm to redline 10 AFR....BALLIN'!!!
I only put down 288hp with 5psi boost....I can't remember my torque?
Gotta get with Gadget and get this truck tuned...I might have a boost leak as well. When it rain...IT POURS!!!
:dontknow:Anybody think I should just give up on the Volant with ram air scoop and just use the TRD CAI???:dontknow:
lol..... i thought it was because the gerbils were getting hot feet! thanks for clearing that up for me.That's because the throttle cable frees up after the first run, giving you an extra couple of inches to play with on the second run :top:.
brandon needs a maf cab and he will rock those numbers.. or a map ecu2..
our trucks are prob around 205 whp stock
