SignUp Now!Check here, and tell me what you think. http://www.xr-underground.com/vb3/showthread.php?t=50051. :top:
i noticed a lot of those n/a set-ups have upgraded fuel pumps when i myself being s/c haven't even upgraded my fuel pump :laugh: when i upgrade my fuel pump what kind of gains should i be expecting?
No gains whatsoever, that's not why u would want to replace it. The stock fuel pump filter can only be replaced as a whole unit that is over $400, when u use a Walbro 255 pump upgrade not only will u be upping the amount it could pump but ur also adding a new external filter that u can change regularly
Yeah I got the 4 cams and springs but no need for cam gears on the 09, they are Variable Valve Timing, on the 08 you need the cam gears as well, which the Ucon offers along with Thermostat.
Get the intake spacer from NST it is proven to make hp and torque its affordable also DTLTH and TCAI are a must for NA build
