- Nov 8, 2007
- 3,149
- 10
Tools:
10mm socket
t30 torx bit
wire strippers
wire crimpers
soldering equipment & heat shrink
basic hand tools
Parts:
Hood pin switch
horn relay
12v LED strips I would recommend measuring and getting 2 long ones and a medium one so you only have to deal with three sets of wires.(I did three short ones (about 1 ft) on each side and 2 short ones on the front)
Wiring diagram:
Instructions:
You have to take the taillight out (two 10mm bolts) and then you will have access to drill the hole and install the switch and wires etc...
Run a 12v power wire from the front of the truck to the back. (you may be able to tap some other harness back there but i already had a 4 wire cable run back there, so i just used that.)
You can see my cable that comes up from the front (thicker one) The thinner cable goes to the relay. Dont mind the white wire its just spare from the cable.
Install the pin switch so that the tailgate will activate it.
from this angle(taken from the drivers side facing the passenger side) you can see the back of the switch protruding into cavity behind the taillight
I superglued the LED strips to the underside of the bed cleat rails
Wire the LED strips together in parallel, run the main leads into the center open cubby hole then in to the relay controlled by the pin switch. This cubby is held in by double sided tape and it kinda clips in. (you can see some of the tape sticking out)
You can run the wires from cubby hole to cubby hole in between the fender skin and the bed side, there is plenty of room to fit your arm in there. I installed the relay in the locking cubby. The locking cubby is held in by six T30 torx bolts that are kinda long and very fine threads.
You can see the black wire, thats my ground and it attaches to a bolt that you can access from behind the cubby hole cavity
Relay mounted
DONE
This is supposed to be a video of the lights switching on and off when I open the tailgate but i dont know if it will work
http://s57.photobucket.com/albums/g230/revobreaker/?action=view¤t=bedlights.mp4
Notes:
You could aslo install an overide switch to turn it of if hauling with the tailgate down. (I can simulate this buy just disconnecting at the relay) . OR instead of using the pin switch and relay, You could just install a maunal switch if desired.
I think that is all. If there are any questions I will try to clarify things
10mm socket
t30 torx bit
wire strippers
wire crimpers
basic hand tools
Parts:
Hood pin switch
horn relay
Wiring diagram:
Instructions:
Relay mounted
DONE
Notes:
