SignUp Now!So maybe we can get a group buy together? Not sure if he'd be interested, but I am willing and looks like others are as well...:dontknow::top:
WOA... i like these alot!!!
if this guy came on the forum.. ID CONVERT!!!
On a more functional note, they appear to be more of a low profile which means they won't be in the way when working from the side like the redline ones.
Looks like it opens the hood really wide, its not too much is it? Can't really tell how the hinges are by the pics.
I think I would as well.
Hmmm.. used redline hood struts for sale??
hey hey...:motz: i have used hood struts for sale..lol
They open the hood all the way. I dunno about the redlines, but these dampers are pretty strong so you may have to guide your hood open intially. but yes, from looking at the pics of the redlines, these are so much more functional if you need to work under the hood.
can you explain that to me, Im not sure exactly what you mean
ok i get it, but after they "break in" they should be fine?
I just installed my new RS type Hood struts and love them.So I went ahead and gave these a shot: http://cgi.ebay.com/ebaymotors/toyo...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Review:
Pros: At $65 with free shipping, they are cheaper than the Redline brand ($69.95 plus shipping). They use factory bolt locations that require no rivoting making it easily reversible. The guy who sells them used his own X to test fit and make them which is good because we know we're not dealing with just any guy selling generic struts. He also provides great customer service over the phone if needed. I found out this as I was concerned when the dampers first did not compress by hand but he walked me through it. They are injected with nitrogen gas and have to be "broken in" initially. He recommended the same method he used which was putting them under his office chair then lowered his weight on the chair to get them to compress. Once that issue was addressed, the overall install took about 20 mins.
Of course I asked him about XRU and whether he knew about it. He said he joined a long time ago but was never much active. Hopefully this gets hims more active :laugh:
Cons: None really so far, I will update this post if I run into any. He did advise me, with these being heavy duty dampers, to guide the hood open as it raises itself. And although it works great, the top bolt should have been black like the rest of the parts instead of gold, but that's just my OCD kicking in :rolleyez::laugh:
Install:
Step 1: Locate upper and lower factory bolt locations to be removed and replaced:
Upper: (1st bolt out of the 2 that attach hood to the truck) 12mm
Lower: (bolt near rubber piece) 10mm
Step 2: Verify and attach parts (12mm socket) to upper bolt location
Step 3: Verify and attach parts (10mm long socket) to lower bolt location
Step 3: Attach dampers. Quick tips: be sure to remove safety clips and re-attach after dampers have been placed on. At first, the dampers are too long to be simply attached to both top and bottom locations. I attached the upper mount first, then raised the hood slightly by hand and attached the lower mount.
Upper Mount:
Lower mount:
Completed Install: :top:
