sdxrunner619
- Jan 20, 2010
- 3,836
- 7
So first things first, i was a gymkhana yesterday. I was just doing figure 8's, practicing and giving rides. I did two back to back runs, and after i went and parked her and let her cool down. Definitely got a little warm, the I/C was hot to the touch, so i let her cool down for a half hour. I got back in and did one run, i finish the run, and pull up to the pits, and my truck is idling like it had race cams or a horrid misfire...Stumbling and what sounded like a misfire. AFR gauge was saying about 17.0...:hmmmm2:
So someone brought up that a coil pack might have taken a shit, so we switched coil packs and plugs. Same thing, barely idle, and running really lean. Then we figured possibly a vacuum leak, and he told me to rev it and should run really rich. I revved to 4k, and as it was dropping down, it went into a fast idle and started making the most horrendous sound ever. We shut it off, checked a few things and fired it back up, same thing horrid sound and only pulling 7" of vaccum, but it was at-least idling. I drove it maybe 15' to the tow truck, and another 20' from the tow truck to driveway at home.
So i called a tow truck and got towed home. it sounded a lot valve train, like a collapsed spring or lifter. a bunch of guys where saying valve train, and the sound was 100% coming from the divers side bank. So i went home and popped that valve cover off, i turned the motor over by hand and inspected everything, nothing looked ****ed up visibly wrong. No scoring on the cam lobes, or valve buckets. (i think that's what they are called) Next we did a compression check to see if we could find the dead cylinder. 175psi in all cylinders, on both banks...:dontknow:
after that we where completely at a lost, so we put it all back together. Another friend came over and i wanted to show him the sound, and he suggested using a piece of tubing to help pin point where the sound was coming from. So we buttoned her all back up and went to fire her up. pay close attention to when the engine dies after the first clip...
http://www.youtube.com/watch?v=O2LvSzrhMRE&feature=channel_video_title
These are the first two attempts, disregard spark plug comment. Earlier, one of the plugs was dropped by a friend and bent the ground in, we where thinking failed wrist pin, and that's what bent the plug. re gaped it and put her back in. We did pull all the plugs on that bank, all looked fine and were hot to the touch. So they where firing, who knows how good...:rolleyez: We put them back in, and went for one more attempt at running and finding the sound before we called it a night. I was also working on 5 hours of sleep, hence the comments that I made, made little to no sense...:laugh:
So here the final third attempt:
http://www.youtube.com/watch?v=sQlPdffhoMo&feature=relmfu
listen to the beginning...you here the sound, then it disappears. :hmmmm2: We let it idle to OP temp. Warmed up fine. we figured, it will come back under load. So i backed her up and drive up the street. No knock or missfire, drives fine. Pulling 21"s of vacuum. I drive back down, still fine. we do a few up hill partial throttle and see if we could find any hiccup's, nothing.... So my buddy is in the car, and we say F-it. Lets see what forced induction does. I nailed it trough 1-3rd, on this expressway. 8lbs of boost and my ass dyno was saying running perfect. I drive back around the block, and park and let her idle. Still sounds fine.
So of course, i had school today and i figured, ah WTH, so i drove her to school. She felt ok on the freeway, only thing is a slight tapping, sounds like and exhaust leak or a loose clearance in valve train. Like a little quieter then sound a SBC would make if you where doing a running valve adj on it. The tapping came in "waves" like it would tap a bit and then die down, then would come back. Listen for it during middle of the video and the ending. This was after driving 20 miles to school. Of cousre to realize our instructor never showed up...
http://www.youtube.com/watch?v=pG8u2-hp5IQ
i drove home and much of the same. feels fine and only thing is a slight tapping. Its been sitting for 8 hours, (along with me sleeping for 8 more hours:rockon, and im about to go run a few more test, see if i can pin point the tapping sound. Now that the engine had cooled down, ill see what else i can find.
Yah so, does anyone have the slightest idea WTH is going on with my truck!?!?!!:hmmmm2: I will post my findings regarding the new noise. :top:
