The Doug Thorley website has good instructions. Pretty much you remove the old oem exhaust manifolds, position and secure the DTST with a few of the exhaust nuts. Then position the cat into the DTST and secure the cat via the lower support bracket. Tack in a few spots while mounted, then remove and weld.
One decision will be, how to cut the cat or header to join them. The header has a larger diameter outlet than the cats inlet. seems some people have removed the narrow portion of the cat inlet and welded the cats conical end to the header. DT in the instructions mentions this by saying it is possible to expand the cats opening to better fit the header allowing easier flowing exhaust.
As long as the link remains good at Doug Thorley this is the official instructions for DTST 2005 to 2011 vehicles. (my total number of posts is to low to allow posting links. I'm not selling or doing anything more than helping others so hopefully this won't get me banned. I'm going to remove the front end of each link, copy and search to find the actual webpage, add three W and a dot in front of each item below when you go to search)
dougthorley.com/install/THY-515%20INST.pdf
for 2012 and later
dougthorley.com/install/517_INST.pdf
PK
