LateOnTheBrakes
- Aug 2, 2009
- 310
- 1
I have had my shifter assembly apart probably a total of five times to swap out to the TRD short shifter and I also fill my transmission fluid in through the top instead of crawling under the truck and trying to pump fluid into the filler hole. The major pain I run into every time is trying to get the little white bushing back into it's home in the shift linkage. I've tried removing the entire assembly as in picture 1. I've removed just the shaft assembly like picture 2. I have tried lining it up with my fingers by hand when I take the entire assembly apart, lubing the outside of the bushing and the inside of the linkage with oil, but I always end up having to hit the top of the shifter with a dead-blow hammer or some other impact force to get it back into place. The end result is my bushing starts looking beat up and look like picture 3. Is there an easy way to get this thing back into position that I am just missing?
