Locked VVTi actuator
Jason from NC had a long post on here about the VVTi actuator on his truck getting locked or jammed and he kept getting weird codes from it.
I have searched and searched and searched and I cannot find that thread. I pretty much can never find anything I search for.
Can someone help me find that thread???
I think I know a guy that is having the same problem and want to help him out.
Thanks!
You can always post your solution here, and leave it up to Jason to find it.
Yea, but I was looking for the solution he came up with but cannot find it.
Very close.
There is another one I cannot find. Done by Jason in NC. I think he is Lex-X or Way to low, BoostClothing or something like that.
He now has a Lexus he cannot drive into his driveway.
Oh... that Jason. He was "X-Travagant" and is now "VIPDreamin."
The search continues...
Awesome.
Can you help find the thread where he had the problem with the VVTi actuator?
I can never find anything.
Thanks!
Awesome.
Thanks!
Well u already know what my problem was so that should help a bit.
GrumpyOldMan
Hey Gadget, Does this help any - it's from a Scion but prolly similar:
[ame]http://www.youtube.com/watch?v=yuKrnIzU4Bs[/ame]
Dave
VIPDreamin
"Mr. Incredible"
G!!!
Sorry I didn't get to you yesterday and i'm still at work now but yardie said you had posted up here.
With the gear I was getting the random camshaft position sensor codes and also crankshaft position code. Noticed it was something more then that after i swapped crankshaft sensors.
Actually the guy from NC who is a Toyota tech told me of people having issues with the VVTI gear usually after a front impact (which is why mine did the motor came from a truck with a front end collision apparently).
Only solution for me was to swap the a working gear over, luckily I had the spare engine to source from the swap. Swapped that one on the motor and it started up and never threw a code again.
Any way hope that helped if not shoot me a call 757-773-1813
So, to summarize, you installed the VVTi actuators from your spare engine and that solved the problem?
VIPDreamin
"Mr. Incredible"
No I swapped out the VVTI gear completly. removed the old one and put on the other.
