I believe that the FJ cruiser big brake kit is 6 lug.I don't think they make a BBK for the 6 lugs. I know matt has upgraded his rotors and pads. May want to get with him and find out what parts he has.
SignUp Now!I believe that the FJ cruiser big brake kit is 6 lug.I don't think they make a BBK for the 6 lugs. I know matt has upgraded his rotors and pads. May want to get with him and find out what parts he has.
:laugh:...i completely forgot that the fronts IFS and the rear is Solid Axle...
well sounds like i'm going to be looking into this...either way i would/am looking to upgrade both my Front/Rear Rotors...:top:
thanks for clearing things up for me...
We really only need them in the front. Just having the slotted rotors and pads upgrade on mine made a differance. We already have larger rotors and calipers to begin with.
Lol no problem.
I'm with you, I hate drums too.... I would like to upgrade the rear someday. But it's all a matter of $$$.
But it might be possible, we won't know till someone get's under there and actually puts a front rotor up to it:biggrin:.
I agree.
A 6 piston will add more weight also. It may not even add that much more braking power, because we are still using the same MC.
I thought the main advantage to a 6 piston is simply a larger area for the brake pad to contact.
For some of the supercars that are running 20's and the rotors and brakes fill those completely the 6 pistons makes sense because they need as much bite as possible.
I personally think that a 4 piston with a rotor to fill a 19 would be perfect for what we need. You would have a large braking area, and it wouldn't really be overkill.
On the rear I don't think you would need anything more than a 2 piston. Maybe a small 4 piston.
IMO :biggrin:
I used Outlaw calipers when i made my front and rear disk setups.
I know of no kit by wilwood, got a part number?
So back on topic... 4 piston vs 6 piston.
Seeing that I've never held a 4 piston caliper or 6 piston caliper I can't say for sure, but I wouldn't imagine the weight difference between the two would be anything to worry about.
With 6 pistons vs 4 you'll have better distribution of pressure obviously. But will there be any real advantage?
How did you decide which calipers to use?
DALLAS how much did those 4 pistons run ya, and the setup for the rear??
Wow I guess my question would be how much clamping force do you need? Do you wanna go as far as stopping so fast the person behind you is having a hard time not a$$ ending your X? 6 in front and 4 in rear is a little over kill, 4 Front in 4 rear will stop you on a dime.
Just my 2 cents.
Well I need as much as physically possible. Remember, I do a lot of racing, so stopping fast is needed.
As far as people rear-ending me because i stop too quick. Well either I don't stop fast enough and hit the person in front, or miss the person in front and take the hit on the rear bumper, or what I usually do is avoid those situations all together. :biggrin: That would be the reason i've only been involved in 1 accident involving another vehicle since I started driving, and that happened within the first year of me getting my license.
Good point, I'm a offensive and defensive driver as well. With you saying the above, 6 in front, 4 in back GO FOR IT. Your X will be a stopping machine! Hell with that set up I'd stand in the middle of the road and let you run your X at me, stop bumper to my knees without a hitting me. :biggrin: :top: Well I'd drink a 12 pack first. :laugh:
I'd say with 6 in front 4 in back you'd throw your entire drive train threw the front of your X with you going through the windshield. :laugh: I would have to say you would stop short of 110 feet with 6 and 4. :top:
And at that point, i would only want a little bit more. :laugh:
I wonder if the MC will need to be upgraded/modded...
As the SSBC rear conversion is only a 2 piston caliper, if I'm going to do a 4 piston rear I will likely pursue a kit similar to Dallas's.
With that in mind, does anybody have any input on Rotora vs StopTech?
