JFrame
- Dec 9, 2011
- 654
Do you gotta cut the Glide?
Edit: Yup gotta cut lol
You shouldn't have to cut anything.
SignUp Now!Do you gotta cut the Glide?
Finally did this mod. Adjusted the piston to the point where it stopped turning. Took it on a test run. I feel like im driving a different car now!
..I also grinded 3rd, trying to shift a bit faster. proof that now my body needs to adjust to the engagement level.
Did you do your own stage 3 clutch install?Yea I just did the chair end and it feels much better. No more play. Actually makes it easer to drive with the stage 3 clutch.
Gadget thanks for the heads up.Be careful here.
I have seen a couple of clutches ruined with this mod.
If you do this mod, you have to make sure that all the pressure is being released from the slave cylinder when the clutch pedal is all the way up. What has happened is that this mod prevented all the pressure from coming off the release bearing and it was acting like the clutch pedal was partially pressed down and the pressure plate was not being allowed to have full clamping pressure on the disc causing the clutch to slip and burn up.
The way to test to make sure all the pressure is coming off of the slave cylinder is to cycle the pedal several times and then see if you can press the slave cylinder into its self by just pressing on it. If you cannot press it in by hand, you are not allowing the pressure to come off the clutch release system and preventing full clamping pressure from being applied to the disc.
A poorly adjusted master cylinder can do the same thing.
So, after you think you have everything properly adjusted, do a final check and see if you can push the slave cylinder in by hand.
