Mr Smack Attack
- Jan 10, 2009
- 455
as long as you don't mix too much black in the clear you should not have a problem. you mix less and spray till you get the desired tint.....
if you do a bsp color get a three stage the pearl would be a clear tint with all the metallic in it
mix the clear and black
spray
get the pearl
spray
get the clear
spray
bsp-ed tail light is what youll have
i did this with mine i screwed up and used a premixed paint (lacquer) and that affected the out come, but i will be using car paint next and it will be BSP
when i did mine in my camaro.. i wet sand the whole tail light 1st before even doing any paint.. so that it would looked smooth... IMO you should wet sand then prep for paint...
