5H4D0WD347H
- Apr 24, 2007
- 10,450
I ran the 2.7 with my combo.
The 2.6 snout machining alone was making things pretty thin...
You wont have to pull much timing providing your fuel is good (important). I think -2 or 3 should do it for a 100 shot (with your current mods) if the temps are reasonable and your running on the rich side of things.
If the nitrous is pretty much a track thing for you just run straight race gas or mix it if you want to be safe.
A 50 shot on boost will make much more power (probably 25% + more) then a 50 shot N/A due to the immediate cooling effect and increased blower efficiency.
A 50 shot probably yields about 65-75 HP & 85-100 TQ
Also take into consideration this all power on demand (the moment the spray hits you are making all of this power, its not peak power).
65 HP+ from 3900 - 5800 is quite an increase when compared with other more linear gains.
I have Map-Ecu3 for tuning. Definitely need to add fuel and maybe pull a little timing. Just wanting the most boost I can run safely then add a little nitrous for cooling
