wisenthefools
"Ricky Bobby"
- Feb 13, 2010
- 662
I'm out for some track trips from you more experienced X-heads. When runnin @ the strip do you burn out in the waterbox or drive around it? If so, whats your method and if not, WHY not? I was talkin to a semi-pro driver/co-worker the other night and he raised an interesting point. He told me that with street tires, alot of tracks actually FORBID you from doing a burnout or driving through the waterbox, because in doing so, you collect water in the tread groves, which runs down on to the track while staging, thus making the next driver (and possibly yourself) launch in a wet spot.
That being said, I don't see how this could be significant as long as you do a burnout and even semi-heated up tires are better than cold ones right? My main question is this: When doing a burnout in a manual, should I powerbrake once I get em' spinnin? I'm afraid I'll just stall out and look like a doucher. We've all seen the big HP guys and they're standing, smokey burnouts. I usually just raise the RPMS, dump the clutch and let the tires spin til' I feel them begin to hook up, then I push in the clutch and get out of the throttle. This method works but makes for a pretty weak burnout and I doubt it heats the tires up all that much. Should I even bother? or am I just doing it wrong? any tips and input will be much appreciated as always.
