Ridefoxone
- Aug 23, 2009
- 155
Hi, everyone. I needed to get some t/s help to locate the source of some issues I'm having on my FJ. I have about 50k miles, with less than 5k on supercharged. Had x-1 installed with exhaust for over 2yrs and no problems before. I'm getting codes po101,po171 and po300. and more resently some sputtering. I'm running the urd mkIII , LT headers and y-pipe,an x-1. Supercharger hasn't been n very long. So far I check the resistance of all 4-o2 sensors according to the factory service specs the tried swapping the front sets ,then the back sets at different times to verify they are good. I also cleaned my mass sensor and also tried another one to test...still getting the same codes. Even tried a different X-1 . I tried also doing a propane test to see if I had an intake leak, but no change in the running. I am curious as to if anyone else has came accross these codes together or not. I haven't tested for exhaust leak yet ,but visually I can't see one or hear one. :frown: Any thoughts?
