Just get the 640cc and the supplemental injector for supercharger cooling. You will have plenty of head room with that combination.
For a daily driver/non racer should the 7th injector be sufficient?
SignUp Now!Just get the 640cc and the supplemental injector for supercharger cooling. You will have plenty of head room with that combination.
Throw the 2.85 pulley on it for cheap HP. Mine added 3psi
Around 360 whp or so. ABP is the one who holds that record I believe.
I had a 375 HP baseline on TRD before spray (93 pump gas); not sure if its the highest though - I thought there was someone else in/around there.
http://www.xr-underground.com/forum/showpost.php?p=887382&postcount=65
And here it is....I was guessing 375....but.....
353.11hp and 357.09Torque, this run was on a dynojet with SAE correction.
URD MK3 with 75 pulley.
URD MK2 exhaust
Doug Thorley gen 1 long tube
Stock Y
URD fuel pump upgrade
UCON with stage1 map loaded
I was scared for a moment...smelt some burnt clutch and I thought I blew my motor. This was run 3. They didn't run with the O2 sensor on run 1 and 2, so I told them to hook it up so I know I am running safe.
They said they ran another blue XR in 2005 and compared it to my dyno. So you can see the improvement. Tuner said he remember URD intake and exhaust, not sure of anything else as in mafcal or not. But here is the comparasion.
Numbers are on the bottom. Sorry for my noobness. Trying to figure out how to link it here. Tuner was impressed by the way on the gains on the other X. Same year in 2005.
