SignUp Now!I wouldnt drive it until you figure out where its leaking from... all it takes is a little gas to hit the header and your in big time trouble...
FYI- I too spelled gas in the cab under hard acceration. I snugged the fuel line to the 7th and it went away. Honestly I did tighten the connection, but just every so much.
Also did you use any pipe dope? Its been said here that gas eats the dope and could cause a leak. I doubt it ate it that fast, but wanted to throw it our there.
What kind of adapter do you have on the fuel rail? you might not have tighten up that 2 small bolts enough.
Yeah no kidding. Grumpy is coming over this afternoon so we'll take care of it. Mark, thx for the offer. Hopefully it's an easy fix.
Yea they should have those clamps that snap over the lines, if you are seeing fuel dripping, then its a pretty big leak and those missing clamps sound like the problem
btw I used some motor oil on my injector o-rings and I have never had any issues
The 2 line that goes to fuel rail, feed & return lines, they snap together with plastic slip cover on top. They were there after the test drive. I'm going with Alfredo theory, pinch hose.
Is that an oil cooler under the filter? if so whered you get it?
Good luck this afternoon.
