SignUp Now!Can you not use the URD traction bars on the X?
Cursed
These are not from my truck, but I remembered seeing this post elsewhere not to long ago so I pulled the pics for you:
The bars keep the axel from twisting the leaf springs. If you ever accelerate over a bumpy road you get a hoppy feeling as the axle loads and unloads off the leaf springs when it is twisitng against the driveforce. The harder you lunch the worse it can be unless you just spin. Even then you might spin and hop at the same time. As you build power and loose traction the bars just keep the wheel and axle geometry from getting outta hand.
You can preload the traction bars bit and stiffen the ride as well. You "tune" the feel.
and still lets the rear end suspension to move independently
