SignUp Now!thanx for the imput. anyone know if the ones from the sequoia will work with out truck?
Glad to help. :top: Would hate for you to kick yourself because you didn't get what you thought you were ordering. :biggrin:
the overhead console is over $900
The ambient air temp sensor behind the grille is like $25 or $30. part number is 88790-22131
so how much was the temp probe?
and where is the wire up front to plug it into?
one quick question, i already have the sensor on my truck can i just go and buy the temp display? its little bit wierd though that ill have the sensor already mounted but no overhead temp display. hmmm i wonder if the stealership forgot to install one on my truck...:hmmmm2:
I know this is an old thread... I have some info from my work at a Dealership.
You can get the Compass/Temp Module only Part#83290-04030
Retails for 305.40 CDN
If you know someone who works at a dealer, you most likely can get them for less than that.
This is only the module, no trim. This was part of the warranty/TSB section and found this PN in Infostream. To get the trim, you would need to order the whole thing for $1000.
Cheers, hope this helps.
