TheAngeryGinger
- May 14, 2012
- 807
I can't see the picture very well but I would say yes. Just make sure the wires going to speakers matches the rca's.
SignUp Now!TheAngeryGinger said:I can't see the picture very well but I would say yes. Just make sure the wires going to speakers matches the rca's.
justin13703 said:Yep the easiest way is to make front left channel 1, front right channel 2, rear left channel 3, and rear right channel 4. Then the speaker outputs on the amp should be labelled channel 1, 2, 3, and 4. Just make sure you connect them to the corresponding speaker.
I saw it said you were on this page and I figured that would happen again. LolDAMNIT you are always faster then me:laugh:
Also something doesn't sound right about the rca's on the back of the radio being labelled as pos and neg. It should be left and right. Each RCA connection is a separate positive and negative terminal.
justin13703 said:Do the rca's just like I said in the post a couple posts up. Also your RCA connections on the amp are labeled 1(L) 2(R) 3(L) 4(R) not what you wrote above.
revobreaker said:Pic of the HU if you can...
