justin13703
- Sep 9, 2010
- 2,771
- 17
I noticed that too but it looks like it might be a temporary thing in the pic.
SignUp Now!justin13703 said:The best thing I can think of for the clearance issue is to maybe take a dremel and grind the holes in the brackets that the radio mounts to into a kind of oval shape, grind them towards the front that way you can slide the radio out a little, then bolt it in and that should give you enough clearance.
The pandora glitching thing happens every once in a while, they're always updating the pandora app trying to fix glitches and stuff like that. As for the Bluetooth, if you haven't already I would try deleting your phone from the radio and the radio from your phone, and try pairing it again. What kind of phone do you have? iPhone? Android? Crackberry?
MORT-RUNNER said:Question, do you find that removing the face plate of the HU is difficult with the Tacoma dash kit? Putting it back on is a pain!
Im not too sure how the spacer thing would work, I cant exactly remember how the radio is mounted in there though. I figure the only way to space the radio out will also move the whole dash kit out which wont really do anything, I could be wrong though. Maybe that would work with the metra kits, I have a scosche so that might be why I dont get it lol. I doubt youll be able to bend those metal brackets though.What I end up doing is pressing the eject button and get the tilt menu, then I press the remove face icon that shows the face tilted horizontally. I then have to press the din down to allow for the HU face to slide down and forward. I then remove face and the HU slides back inside the din. Putting the face back in is a pain. I put the face in top first then push the din down to clear the bottom on face then press on the edges of HU to lock it in. It's a pain.
I have tried removing the gap filler piece on the din kit but this did not help. The HU still has issues clearing the din kit at bottom. From the way it sits inside the dd kit, it looks like it has plenty of clearance at the top and not enough at the bottom. I'll be attempting to bend the brackets up a touch to get the HU a Lil more snug near the top hopefully allowing more clearance at the bottom.
If this does not work I will try dremel ing the brackets that screws into the HU to ovals like Justin said to try and get more clearance this way. But if bending the brackets does not work, I'm not sure the dremel ing will have any effect on clearance and may have to try the longer mounting bolts for brackets with some spacers to allow the HU face to stick out of the din kit enough to give it clearance to be able to tilt and slide out and open. If that fails I will have to figure a way to cut the bottom of dd opening and still have a clean look.
As of now I'm just forcing the bottom of the din kit down long enough for the face to open and close. Sucks but it works. I don't want to mess the motor up on HU that controls tilt and eject feature so I'd like to fix this clearance issue soon. I am always removing the face when not in car in fear of some punk seeing it and smashing my windows and stealing it. I got the 5901 but I don't think it would stop a smash and grabber. Alot of scandalous people out there.
I would get at least a 2 gig card depending on the size of the update you need to run. I have a 4 gig that I leave in mine and it was big enough to do the map update a few months ago so a 2 gig for yours should be fine. Its usually a simple process to update the pioneer radios, and they usually give instructions of how to do it on their website. As far as putting pictures on there, I may have to research that because Ive never had an AVH series so Im not exactly sure on that. If you cant get around to doing the full Big 3 for a while, the easiest thing to do is just throw in an additional battery to frame ground using the same gauge wire that you used for your amps. This alone should help out a bit, and is pretty simple to do. Im glad everything is working good and sounds good.Just saw this right now. Well I still haven't deadened the roof but I do have enough raammat to get it done.
I just bought a house and have been busy moving and unpacking. Down side to new house is I don't have a garage to work in, I'm working on a solution for an area I can have to work on the x and any Lil projects.
My system is still bumping and the sub is nice and broken in now. I haven't had any issues other than the iPhone 5 coming out and me having to find a way to hook it up to the HU since the plug is different than pervious versions. I Recieved an email from pioneer to update the software on the avh-8400. I have to download it on my computer then save to a memory card or flash drive to be able to update the HU. So I got to figure that all out and see what it's all about.
I was wanting to get a few new background for the HU so I'll have to figure out how to do this as well.
Overall I'm very satisfied with the 8400 and love using pandora as well as net flicks and navigation via iPhone. The break bypass works great, no issues other than having to pay attention to the road when watching movies, I use it mainly for my kids when they are with me. Doors speakers are crisp and clean sounding and the sub bumps.
Things to do, big 3, raammat the roof, software update, move box so I can get my jack and lug/ tire bar thingy out just in case, battery terminals- witch I have had since original install just never put them on, flip that bar on the underside of passenger seat so I can slide the seat forward and back.
You guys really came through in helping me out getting this system all pieced together and installed. It bumps and haven't had any issues. I love it. Just what the x needed. Lol.
Thanks again fellas! Now if anyone can recommend a good flash drive or memory card that I can use for my music and that software update, let me know, I haven't used this feature yet on the HU. Also if anyone knows how I can get different backgrounds let me know. Much appreciated.
