Shanes56
- Jul 27, 2007
- 3,061
:rock:Sittin Sic Drops:rock:
Specifically engineered for the X-Runner in mind it gives a 1.75" coil drop in the front and a 2" block drop in the rear! The coils were specifically designed to make the racer and cruiser happy. 15% (775ppi) is the magical percent that gives you a tolerable ride for the daily commute but also gives the extra support in the twisties. By increasing the spring tension by 15% it limits the amount of body roll when attacking the curves. This is a great upgrade on its own but in combination with a good set of low profile traction bars and high quality sway bar bushings, the claim of handling like a 350z seems to be just that easier to prove. Below the pictures and pricing I give my critical and detailed review of this product and I invite anyone to post questions about this kit and I will answer them a soon as I can.
Sittin Sic Drop Kits come with everything you need to get your X Sittin Sic in the parking lot and in the corners.
Included in the Kit
High Quality Polyurethane Bump Stops
2" Aluminum Drop Block Kit
Front Coils (painted with the option of powder coating for additional fee)
Price: $300.00 + Shipping to the lower 48 (destination charges differ)
If interested in purchasing please PM me or visit www.sittinsic.com!
Testimonial
So far I have no quams about it beside the pain it was to switch the springs, I recommend to anyone that is going to replace spring have a professional do it, it will be worth the money spent. I like that my handling has gotten a little tighter, not a dramatic amount but there is less body roll in corners (with sway bar bushings this will be a fantastic combo), also in the same respect, being that it is only a small % rate (spring tension) increase the ride is fine, stiffer by a little. alignment was not an issue, the toe was perfect just had to futz with the caster/camber the slightest amount and it was back to factory specs. In the three days that I have been driving with this kit I have not bottomed out a single time. Overall this kit is a suspension upgrade, if you want to improve in the twisties this is a great kit, but if you don't want the performance or the pain of dealing with spring replacement there are easier kits to install out there.All in all I give it a:
9/10 functionality (could be stiffer)
8/10 Form (installation is not recommended for the back yard mechanic, potential life hazard removing springs)
10/10 Looks (I think it sits at a perfect height)
