I will probably do this. Last time I talked to Darton they did not make a kit. Talked with a shop that does this and it was around $3700 since there is no kit available. Once a kit is made I would expect the price to drop to around $2800-3000.
SignUp Now!INDEED! whats the word G man?Bu-uuuump
Bu-uuuump
sounds complicatedYa, I am going to TRIPLE Charge it!!
So, to do that you can use a magnetic clutch to disengage the Modified Roots type compressor and a flapper valve to bypass it from the system once the turbos spool.
thats just a little bit redonkculousIt is not as hard as you think.
The hard part is to prevent the most inefficient part of the system from bringing the whole system down.
I helped a little on a project like that in Cali. It was on a BMW show car. It turned out great and has nitrous to boot. It is a real work of art. I will see if I can find a picture of it. It is really something.
Found it!!!
Thats a really good idea! Do you think APR is going to try something similar with the "compound" turbo set up they are working on?
