Redlantern
- Jan 28, 2013
- 526
- 6
Wooohooo. Excited to see Goldilocks runnin bro!
SignUp Now!orange is a great color. hopefully that turd of a motor likes you better lol
What I was certain was a head gasket leak, turned out to be because of this. In better detail tham I elluded to in your build thread Iniazy. Turns out that valve in the new Snap-Op compression tester, had gone bad. The spring on it had blown out, so it wouldn't hold pressure. Figured that out while working on another person's vehicle. So retested my suspect cylinder, with a new valve installed. Low and behold, 175 psi compression. Here is the bad valve, with the exposed spring.
All cylinders testing good, there had to be a leak somewhere else. Sure enough, when pressurized, the radiator had a steady small sized stream coming out of the bottom of it. So it has a crack in it somewhere near the top.
Here is the video of what I found with the radiator.
https://youtu.be/brZqeFTt2_o
