>>Flywheel bolts, 61lbft. torque in star pattern. (like lug nuts) blue loctite is not required, but i like to throw some on there for good measure...
>> Pressure plate to flywheel, 14lbft. same thing, star pattern, and little by little. make sure it is pressed on evenly. check clutch alignment too.
>> Trans to motor bolts 17mm head= 53lbft
14mm head= 34lbft
>> 65lbft for the drive-shaft to pinion. PUT RED LOCTITE ON THEM!!!!! trust me....
if you need anything else, HMU on PM, i usually check here often through out the day.
