Whitebeauty
- Oct 15, 2011
- 5,237
Well finally, and if you all only new the things i went through with this engine. Im gonna leave this here for now and edit it later. Just wanted you all to see finally. Thank you to everyone that has helped me and its not done yet. Pending 2 new O2 sensors to install and then we begin the tuning.. Also as u can tell the engine bay is black now..
Current mods:
Engine:
Fully built 1Grfe
LCE rods w/ arp2000 hardware
JE pistons
ARP headstuds
Cometic head gaskets
Ferrera Valve train
TRD S/C modded by Stiegemier: Everything except the snakebite.
Light weight rotors, Venom cooler, Ported,and direct drive coupler installed.
Throttle body bored and throttle plate shaft modded as well.
APR X1, cam gears and T-stat
Walboro 255lph with external filter.
61lb injectors- running E85
APR fuel rails
-6 feed and return lines from fender.
APR 7th
Tomei FPR with fuel pressure gauge @ 51psi
APR 2.6 pulley
NST overdrive pulley kit
Volant cold air intake
NST wp/alt/ pulleys
ARP Exhaust studs
Dtlt headers
Magnaflow muffler
Dual vibrant resonators
custom y pipe
Dual pipes after the muffler
AFCO ALuminum Radiator, Dual row
Dual E-fan
OEM oil cooler
Cusco oil Cath can
Drivetrain:
External tranny cooler and cooler in radiator.
Upgraded valve bodies.
Suspension:
Rotora 355mm 6 piston fronts and 4 piston rears
Tundra racing 2 in lowering sleeves in the front with bilstien shocks
Custom air ride in the rear
Addco rear sway bar with ES poly bushings and bilstien shocks.
Wheels:
Work Crag sk5
20x9 +15 all around with a .5in spacer in the rear wrapped on BFgoodrich KDW 265/50/20.
I believe thats it...lol
THANK YOU XRU!!!
Short story on my build:
http://www.xr-underground.com/forum/showpost.php?p=946436&postcount=16
Current mods:
Engine:
Fully built 1Grfe
JE pistons
ARP headstuds
Ferrera Valve train
APR fuel rails
APR 7th
APR 2.6 pulley
NST wp/alt/ pulleys
ARP Exhaust studs
Dtlt headers
Magnaflow muffler
custom y pipe
Dual E-fan
OEM oil cooler
Cusco oil Cath can
Drivetrain:
Suspension:
Wheels:
Work Crag sk5
THANK YOU XRU!!!
