madtrucker
- Feb 28, 2012
- 1,376
- 75
I'm learning alot here. Please continue. What do the pros use? Expensive stuff paid for by sponsors I'd imagine.
SignUp Now!I have driven a lot of trucks on the road with automatic lockers like the Detroit. You are not going to want one of those at all.
The only thing I would consider is an ARB Airlocker or a spool. The ARB is very nice, just flip the switch and it is locked and stays locked. Flip the switch again and it is unlocked. It is the strongest locker on the market for Toyota trucks.
Other than that, I would get busy with a welder again.
Finnaly found a website with some folks talking about Detroit lockers and drifting...on a poo-stang forum, of all places...they say when you let off the gas it unlocks, similar to a one way diff.... that is no Bueno for the level drifting ill be doing....welded diff it is then.
Pretty much, shimming your stock LSD would yeild a Detroit locker....it wouldn't peg leg, but the off throttle behavior patterns are less the ideal for drifting duty...
99% of drivers who want a LSD, just want it for the stopping of pegleg burnouts, so the majority of them only lock under acceleration. For drifting, a two way or 1.5 way is needed..
PS, I kept my radio. its nice to drown out the drone of my exhaust, every once and while with some Rise Against....plus, I just realized the music really calms my nerves when I get ready for the start of a competition.
[CODE]
Yup this is true although there are many advantages over an LSD (though it seems not for what your doing with it) with lockers.
The second you pull one wheel off the ground with LSD your done - but a locker will keep you moving if you do the same.
A locker also doesnt slip like an LSD you are transmitting all the power you have to the wheel(s) with traction all of the time on or off the ground. The LSD I think is said to transmit 40-60% while an autolocker will do 95%
This is where the disadvantage in the front axle of a truck is with auto lockers comes into play... During normal conditions the locker in the front axle is pretty much transparent since there is no torque being applied to it. Now if you put the truck in the snow in 4x4 now your locked all the time and it can be hazardous to steer as the locker will try to fight you (some can drive like this no problem others cant). This is why a selectable locker in the front of a street vehicle (be it air, electric, manual, w.e) can be beneficial and a rear auto locker really isnt a big deal.
In the rear the locker pretty much locks under throttle and unlocks coasting around turns (which is what you want and what its designed to do).
minispool it is!
just as a wondering thought...
SDX isn't your truck your DD? why dont you get two rear axle assembly's??? one "normal" for DD and have a welded for your drift events??
your welded ones are getting tore up from daily street driving with normal turns...
i couldn't imagine it would take too long to undo the u-bolts, shocks, and drive line...
the only PITA would be the brake lines...
How about trying a prius or camry diff? Those would work better for your application sir :top:
Still didn't clip them fog wires. Jesus. Lol
I think its the old 8"
Its is. That stlye 3rd member wont fit into our housing. Diffrent bolt patter. Even though we (8.4" slang for ours) technically use a 8" ring gear like the old 8" diffs, the holes for the ring gear bolts don't even remotely line up.
If you want to know everything humanly possible About Toyota diffs, here is my rear end Bible. I confirmed this info with a local gear shop, and as far as he can recall it is all correct.
http://home.4x4wire.com/erik/diffs/
Im guessing you've never pulled out one of our rear ends or 3rd members? Its very labor intensive...
correct i have not removed one....
yes get a new DD... i paid $500 for a 91 civic with no ac... the main keeper for me is 46MPG!!!!!
Only one way to find out
