SignUp Now!I think we will see some serious powa from people as the temps get down in certain areas. Names I will not diclose......:rofl:
The TRD X-Runner got 400 HP, but they changed the internals:
Highlights:
[*]Power increased to 400 hp and 350 lb.-ft of torque
[*]TRD - designed supercharger & intercooler package featuring an Eaton Roots-type supercharger with an integrated air-to-liquid intercooler.
[*]Fully functional hood scoop
[*]TRD - modified internal engine components with new pistons, connecting rods, camshafts
[*]Kaiten billet steel flywheel, 30% lighter than stock
[*]Aisin heavy-duty ceramic metallic clutch
[*]DC Sports true-dual polished stainless side-exit exhaust system
[*]Lowered ride height with added underbody aerodynamic components
[*]TRD 4-piston aluminum calipers front & rear using TRD 355 mm drilled rotors
[*]HRE wheels 3-piece forged aluminum 20 X 9.5 fronts & 20 X 10.5 rears with Pirelli P
Zero Scorpion tires (front: 265/40/20 & rear: 295/45/20)
You'll probably over spin that supercharger to get 400hp and might even break it.
Over here in Australia we have the same arguments about dyno figures and couldnt agree more on what XrunnIT has said about the strip (1/4 mlie) is the only way to get a true indication of a cars power and XrunnIT's car is a good exapmle of the power of the TRD s/c, his mph and the weight he's at puts his car around the 330-350rwhp, correct me if Im wrong he's running a 3" pully, so add a 2.75" pully (about 4psi) and that 400rwhp would become very real in the right conditions.
Dynos' are way to easy to manipulate to inflate figures, hell I've see 50-60hp difference from one dyno to another dyno. Dyno are only tuning tools you cannot accurately compare.
Highlights:
