Official Aftermarket Wheel and Tire Spec Thread
Venomous_X
^ So much Win! Snoopy did you have someone come and measure for your fitment professionally, or did you come up with your own measurements?
dramad1
Snoopy them rims and tires are bad ars. I like alot.
Snoopy_TXR
It was more of a guess lol. The guy I bought it from let me borrow the rims for a test fit. To my surprise they worked! It came off a Maserati Quattroporte.
thanks bro!
Venomous_X
thanks bro!
Alright, I gotta know how much you forked over for those babies.... Those usually crank for 1200 a piece, and you can PM me if you'd rather keep it discrete.:adore:
RMCO
Wheel- HRE 948R Matte Black Center and Gloss Black Lip
Front-
offset: +53
width: 10"
tire: Nitto NT 555 (275/35/20)
Rear-
offset: +46
width: 12"
tire: Nitto Invo (315/35/20)
Drop- DJM 3"/3"
BBK- None
Trimming- None
No clearence issues? They look amazing!
Snoopy_TXR
Thanks. There was clearance issues. The front wheels were rubbing against the sway bar on a full turn. I fixed that issue by adding 25mm spacers. For the rears, the oem wheel studs were a bit too short to lock the wheels in safely. I removed the rear drums and replaced the wheel studs with longer ones I bought from Napa. Shout out to Torspd for his "ARP Wheel Studs" thread and tacomaworld.com. It had all the wheel stud info. I needed on there:top:.
czar_dom
Those wheels look very nice Snoopy. Nice upgrade. With that much wheel and rubber bet your taking a hit on gas mileage now :rolleyez:
D.A.C
jeremydittrick
HAMANN HM2 18X8.5 +13 OFFSET, wrapped in NITTO 555'S, 255/45/18
NO SUSPENSION MODS
Front-
offset: +53
width: 10"
Rear-
offset: +46
width: 12"
Drop- DJM 3"/3"
BBK- None
Trimming- None
Your setup looks really good, 315s in the rear must look crazy from the rear. :top:
ultraxr
Front-
offset: +53
width: 10"
Rear-
offset: +46
width: 12"
Drop- DJM 3"/3"
BBK- None
Trimming- None
Sexiest stance by far on any XR i've seen. :adore:
Mr.X
WHEEL: Enkei RPF1
COLOR: F1 silver
FRONT:
- Offset +15
- 18x10.5
- 255/45/18 Federal
- DJM 3inch LCA/UCA+ stock height springs
REAR:
- Offset +15
-18x10.5
-285/40/18 Goodyear F1 Supercar
- SS leaf+ 1.75 block (overall 4inch drop)
TRIMMING:
- yes about half a inch or a little less only in the rear tho
BBK:
- yes
Sproulesxrunner
Front-
offset: +53
width: 10"
Rear-
offset: +46
width: 12"
Drop- DJM 3"/3"
BBK- None
Trimming- None
I really want those rims in that offset/width. :fok::allhail:
Bump for more pics!
Thank you sir. :top: Really dig your wheel choice. Perfect complement to you ride. Have had HREs on the back burner for the longest.
As for the gas mileage post, those wheels and tires combined, I bet are barely heavier than stock, if heavier. I also bet that the over a diameter is larger than stock by just a hair, so if that is true, then he should actually be seeing better mileage when cruising due to lower rpms.
xrgilly
daialloy
18"x9.5" +35 on all 4
stock rubber
XII coils and monoleafs
revobreaker
I finally get to participate!
Wheel- TSW Zolder 5
Front-
offset: +20
width: 8.5"
tire: Nitto NT555 (255/35/20)
Rear-
offset: +25
width: 10"
tire: Nitto NT555 (275/35/20)
Drop- Original SittinSic front coils and Composite Leafs
BBK- None
Trimming- None
lovemym
Xxr 530's Chromium Black, 18x8.75 and 18x9.75 + 20
