Everyone please comment!!
Click
I don't come on here much, maybe once a month, sometimes not for months. Not much action in this area and I opened a pub/bar which takes all my time so I don't have much time to check sites. I went out to the garage and looked at my truck, it's an AFE cold air intake. Haven't driven it in two years because the tabs are expired, and since I own my own business, I have no money. I put money into my 91 Toy to get the motor going and new tires, it's really my daily driver. 471,000 on it, bought it new. The X sits in the garage. Would like to see more action in the NW section.
RHD
Hello
I get on here maybe once every 3months maybe.
Wayside
I may be late but i am here
Tom from lets call it Woodstock Ontario
I usually don't log in but i am on usually about once a day
original owner since 8km
2014 BRM 1 of apparently 4 that are in Ontario according to the dealer i got her from
AFE Magnum force stage 2 si CAI
colour matching leer tonneau cover
wet oakole seat covers
yes yes i know it mostly stock but its still fun :D
Hello
I get on here maybe once every 3months maybe. View attachment 22336 View attachment 22337
Can you tell me what you did to add that data display to your center console? Did you buy or build the trim plate? What kind of display is that, and what software are you running on it? And last but not least, what are you doing for stereo? Are the steering wheel audio controls still functional?
It looks beautiful! Great job!
GT7
Come here probably once a week.
Trd supercharger
Full urd spec-u.
Valve body upgrade because Im a 5spd.
SoFloBlue
From South Florida.
On here about once a day, sometimes more.
2011 SWB XR original owner.
URD Mk3 supercharger stage l
URD short shifter
URD MAF calibrator
URD Spec-U LT headers
Prosport white EVO series wideband and Boost gauge mounted in flex pod
LED fogs
TheLightBringer
Jason Nazareth PA
turbomach1
Memphis TN area.
130k
After a month's wait for brakes from URD.
RHD
Thanks. Its an ipad mini 4 with dash command app connect to obd via wifi. The ipad dash was done by soundman on youtube here is one of the videos
. The ipad is connected to a sony deck via bluetooth which i installed in the glove box. Scosche has a dash mount for an ipad for a 2012 -2015 tacoma but I don't know how good it is. Oh and yes the steering wheel controls are still functional.
autobodyX
2009 SWB second owner purchased from member AZburnin after the second meet up st Virginia international raceway. The 09 is my second X. I purchased a 2006 RR new off the lot and sold it after getting the 09. I check the forum daily some days several times. I use mine for work and play, l am not afraid to use it as a truck or go do a track day and fun with a bunch of fast cars.
TRD supercharged with 2.85 stealth Pulley
Fuel pressure regulator mod
Doug Thorley long tube headers
URD 02 simulators
URD compition Y-pipe with big single magniflow catalytic converter and 3” exhaust threw magniflow muffler and tip
URD 160 thermostat
URD speed unlimiter
URD fuel pump kit
URD lightweight flywheel and stage 3+ clutch and Throwout bearing kit
Clutch accumulater delete
Coupe modded TRD short shifter and redline MT fluid
Coupe weighted shift knob
Toyota factory oil cooler
Detroit Tru-trac LSD with redline shockproof gear lube
AFE cold air intake with URD air filter and custom true cold air ram air inlet.
Custom track day tailgate spoilers
Custom street/daily use tailgate spoiler
E-fan
DJM 3/4 drop
XII performance sway bars
XII performance springs front and QA1 rear shocks
Custom bump steer correction kit
Custom front sway bar end links to correct for drop
Stop-tech BBK with isF rotors
SBC rear brake conversion
ATE brake fluid
Custom stainless brake lines front and rear as well as clutch line.
Carbotech hp10 pads front and rear
Custom brake cooling ducts and fans using screened fog light holes for inlets.
Firestone air bags to adjust rear spring rate.
Hood scoop delete
Grillecraft grill insert
Color matched. To the dash pad, radio face late
I haven’t had my X runner in 4 or 5 years but I still get on here at least once every two days. It has definitely slowed down a little but this has been by far the best forum I’ve ever been on.
I bought a house and needed a bigger truck so I ended up with an 08 ram with 35s, and bought a Cam Superline 6x12 dump trailer. I’d throw a pic up but I haven’t posted any pics on any forum since photobucket decided to be a bunch of assholes.
The "Upload a file" button works very easily. The image is stored locally to XRU. Then from there, once it's uploaded you can embed a thumbnail or full image directly into your reply.
lingenfelterm
2005 Speedway Blue (90K on the odometer)
URD SS
URD Clutch & TOB
URD MAF CAL
K&N Intake
Borla Pro XS Muffler
Morimoto LED Fog Lights (Not installed for this picture)
Tonno Pro Lo-Roll Bed Cover
Other Misc... I am on here at least once a week. My future mods include URD equal length headers and exhaust (when it's available again), BBK, possibly shocks and lowering kit, headlights of some kind... Depo ones developed spiderwebbing cracks in them after 14 months of use.
ADAMANTIUM
Up here in Ontario. Black 14 XR, owned since new. I check in once in a while. Waiting until things start wearing out before doing a lowering kit, tires/rims, and then a SC. Unfortunately the SC costs a fortune with the exchange in Canada...but will still be cheaper than buying a bigger truck with more room and more power and with better MPG.
Only have a URD short shift for the time being.
