skilledbum23
- Jul 6, 2007
- 2,018
well i got the 0172 and 0175 coeds thrown at me appreantly i am too rich........ hmmmmm i guess i need to have it tuned then?
SignUp Now!are you running a wideband?
Justin
yea i got one... guess i could see what my ratio is too
definately check your afr mine with the stock map would put me 9.7-9.8 at wot, and I never threw a code saying I was too rich. hopefully its not a problem with the injector or AIC.that would tell you if you are really running that rich
should be 14.7 cruising
12.1 in low bost
10.5 -11.1 WOT (mine will even go as rich as 10.1 but im running super safe)
Justin
well trying to connect to the ecu and it keeps saying error communicating with ecu check connection and power to ecu....... any ideas???
idleing my wideband is telling me i got a 14.9 afr
at idle the FTC isnt doing anything, the injector shouldnt open unless your in boost. so the stock ECU is keeping the 14.7 ratio. whats the reading a WOT?
Justin
wot...FNG what wot mean while on throttle?
