blackx-runner
"White Flash"
- Jan 14, 2007
- 7,581
- 13
Thanks for the replies, guys!
As far as engine management goes, I have a Chiptorque Xede wired in, it came with a 7psi tune, I took it to my tuner and he said its extremely safe.
So going from that step onward I just wanted to make sure I was doing the right things before I make an overdrive pulley for the crank.
By all means, please keep the comments coming!
The oiling issue seems to be a common one, I do check mine every week and the level is as stable as a rock. I guess on that point, also, what oil are guys running with success?
Thanks a heap!
Jap
I don't think you will have oil problems. The X-runners have very shallow oil pans and during hard cornering and accel the oil can slosh away from the pickup and starve the engine of oil if its not kept full. I am guessing you have the same oil pan as the 4x4 guys. That has a deeper sump.
As far as pulleys an overdrive pulley for the crank is available from NST. You may want to check that out before making your own. There are some clearance issues with other pulleys when you go bigger at the crank.
Another option is smaller supercharger pulley. Those are available from APR and URD. The APR unit looking completely stock.
