Murderface
- Feb 27, 2008
- 11,937
- 2
So since I've have a AEM weldless bung in my basement for over a year I decided to finally use it. I've been using the center runner bung on my JBA long tubes for about a year now and needed a more accurate reading. I had ordered 2 different size weldless bungs for when I had the 1st gen DTLT's so I could install the wideband in the collector since I didn't have access to a welder. Found out the 1st gen DTLT's are actually smaller then 2" but close enough that neither weldless bung kits fit.
So I decided to drill a hole in the section of pipe behind the pass. cat on the y pipe and before the flange that's before the merge collector, install the weldless bung kit since it worked there, and move my rear O2 sensor to this location(remember I have an X-1 so it being here now won't matter). I then put my wideband in the O2's original location before the cat since both my collectors have my WRAF sensors in them. My readings are much more stable and more accurate now.
Here's some pics of a stock y pipe and where I put the weldless bung(I didn't take pics of what I did sorry) but I will this weekend when I replace my trans output shaft seal
