Check out my trans!!!!!!!!!!!
TheArkansas"X"
OK guys check out what we found wrong with my old Trans. That came out of my truck last year. I left it in Dallas the the TOYOTA training center they took it apart and found part to the 5,6 shift fork broke and 2,3 syncro spring and the syncro keys broke. so if any one had there trans stuck in a gear before a shift fork is broke and the grinding may be coming from broking keys and or springs.:driver: :driver: :driver:
inny
if you find the 4th to 5th gear shift problem i'll hire you a few hookers :biggrin::biggrin:
s/chargedxrunner06
Toyota Master Tech
It's going to be the same problem for the 4th and 5th gears also, syncros,detents,detent springs and shift fork wear and or broken.
s/chargedxrunner06
Toyota Master Tech
Good pics Chris :top: , actual not a hard fix syncros, detents and shift forks
4VsX
Rebuilding manual transmissions are awesome and fun! Rebuilding automatic transmissions are not as much fun. :smile:
s/chargedxrunner06
Toyota Master Tech
:laugh: "Automatic transmission" you can say that again, I've done more than I care to.
ok lol? atleast they took time to figure it out :top:
Looks like i will be seeing what the dealer will do for me, my truck got stuck in 6th with only like 8k on it, its always been stubborn on 2nd and 5th tho, just holding out as long as i can to get it replaced.
JA-Xrunner
can the Supra TT 6sp box be interchangeable with the 6sp tacoma one?
You know, i was looking through some pics of the supra 6 speed and that thing looks pretty dang close to the same design as our tranny as-well, very good question... wheres Jim? :biggrin:
JA-Xrunner
i want to know if its the same lenght and whatever and if our drive shaft can bolt up on it?
4VsX
there is so many factors involved to swap trannies one of the main ones is the clutch pressure plate bolting in place to the flywheel. Another huge one is splines.
