J
JDUB916
Guest
Hi guys, I searched the forum and didnt really see my issue anywhere and was hoping if anyone had some insight.
I went to go put my truck in the garage, I started it up sounded fine, put it in reverse to back out, and when I started to release the clutch it shuttered, you could feel the truck felt like it was trying to grab. I stopped and attempted to pull forward, however it felt just the same.
At this point the light had not come on. I turned off the engine and sat for a minute. I started it back up, and tried the steps once again and had the same results.
I stopped the engine once more. Sat for a second and thought. On the third attempt it felt normal this time, however the MAINT REQD light flashed a few times. I pulled into my garage and stopped the engine. I started it again and put it in reverse but the shutting did not come back.
I know the light points to an oil change, however the light does not stay on, it simply blinks several times. I just changed my oil approxamately 800 miles ago and the truck has been feeling fine.
I have a 2006 SWB with about 20k on it. Spark plugs dont seem to need to be replaced until 35k. All my maint is up to date and I cant think of what the issue was.
Any ideas before I talk to Toyotal sometime this week when I have the chance?
Thanks alot.
Thanks alot.
