SignUp Now!Any word on this?
don't know much about this, but if coil overs are made for our trucks, would it be just for the front?
to me all we need is an adapter plate so we can bolt and coil over on that uses a double eye bolt mooting system
I am using the procomp adapters. The might be the same bolt pattern for your trucks.
That's an easy thing to make. Just take the plate from the struts we have, make a template and have a water jet guy shoot a few out (unless you want to cut them out yourself), then just attach some grade 8 bolts through the holes, get some prefabed shock tabs, weld em in, gusset them, bada bing bada boom. Then just get the measurements from there and your done.
i can do them with my plasma cutter then weld em up myself just gotta set up my garage again :canada:
