Bulldogger
- Oct 30, 2011
- 616
How much boost can the 4.0 v6 take and still get decent longevity from it.
SignUp Now!How many licks does it take to get to the center of a Tootsie Pop??
Way to many variables to provide a decent answer.
Well 10 psi on what size of turbo or supercharger? I mean it's like saying 10 psi on a t28 compared to 10 psi on a gt35r..... a zo6 on 8-10 psi won't last as long if it's the gt35r now compared to a t28.... it's a dumb comparison
Well that's not really correct because on the GT500 you can run a TVS 2.3l or a KB 2.8 mamoth both can make 700rwhp. The mamoth has more potential for higher horsepower, but when properly pullied with a 3.0 will make around 700 rwhp safely . It's only a dumb comparison if one is moving consideably more CFM then the other. Being URD is using a Rotrex supercharger I'm sure they priority size matched one to the 4.0 engine, similar to the TRD. Just like Vortech makes a v-1 to a v-9 and a v-20 unit based on different applications, but based on your dumb comparison comment I'm sure you already knew that.
Besides if you bothered reading you already knew we are talking superchargers not turbos
Not really, figuring a safe 93* octane tune without max timing, how well can the ring lands hold up.
I'm running a stock Z06 with 8lbs along with hundreds of others and longevity is making it easily 60-70,000 no problems. Turn the boost up to 12lbs and you're done by 20,000 miles. You sell supercharger kits you must have some type of idea.
Well the rule of thumb for just about every engine usually is 40-50% power increase = reliable power.
The stock motor puts out around 200 WHP, which means low 300s would be extremely reliable providing there is no knock.
400 HP is probably the absolute practical edge (should last a while) for a DD that is only romped on here and there; start putting real hard race hours on it and expect it to fail sooner then later.
I ran a TRD blower and used some nitrous when I really wanted to whoop some ass, it was a very reliable method of doing things.
You can introduce every variable that you want but one thing seems certain.... Below 400 WHP is safe with a good tune; above that you are pushing the limit just based on stock power output and internal component quality.
4-500 HP all bets are off and its a matter of time.
Turbo, supercharger, nitrous, w/e your poison - below 400 HP with a good tune should yield a good time for a while.
:crinklehair: Yes because you clearly state here that you are talking about superchargers at 8 psi on your zo6.... because you know... we all know what you have done to your zo6...... :laugh: The only dumb one I see here is the one that doesn't have information on what he wants a question answered for... As Justin posted the chargers vary in size quite a bit on the rotrex kits. :top:
This should have been your question. How much power reliably can this motor handle.... not how much boost can it handle...
Take it easy x-roller, quit jumping down the new guys throat! Always stirring the pot! Obviously the intented question is what can the 1GR handle?
I think deathshaddow put it best, it seems under 400hp is ok. Above is pushing it. We had one member with a fully modded TRD set up that was pushing close to 350 hp take his truck past 100k while another member didn't add boost(urd mkII) until he was at 120k and something like 10k later still going strong.
Agreed with ShadowDeath. TRD s/c at 8 psi will last you in the 100k range. Then you will most likely need to replace head gaskets. Depending on supporting mods, that will be between 315-340 whp. Nothing insane.
The URD MKIII will net you just under 400 @ ~8.xx psi. cannot remember the torque. Efficient system. Will be coming with a very nice ecu, and the tunes are usually on the safe side for that specific reason. Reliability and longevity. You can adjust to your heart's content as you please though.
The rear two cylinders are prone to knock, due to being much hotter than the fronts. Thus a safe tune again is key here, no matter which s/c you choose.
If you really want to help it last, swap out the weak oem head gaskets first, for the Cometic ones, and some ARP studs. That will help with the safety factor considerably. :top:
Really you should calm down with the off of the bat insulting demeanor. Not helpful nor necessary.
Boost is obviously going to be related to the amount of horsepower. As you know 1lb is equal to about 10hp, therefore one is related to the other. we are not talking about what happens with a crappy tune or bad gas. The quetion was simple how much boost can the engine handle I assumed the answers were going to be based on a good tune. As far as the Vet goes it was an example that you absolutely can have an idea of engine longevity based on boost levels. Companys like A&A Corvette and ECS can tell you how much boost you can run safely. The guys on the vet forum also have a real good idea. That doesn't seem to really be the case over here. Only 1Gracer stated the amount of boost he felt was safe.
Some of you guys on this forum must be at a certain boost levels and racked up some miles by now.
Thank you simple answer of what I am looking for.
As far as X-roller goes all forums have guys like him.
I knew you guys were out there:top: I haven't decided which supercharger kit I want TRD or URD. URD still needs to finish up ther APRx-1 replacement so there not ready yet anyway. I see advantages to both set ups so I still need to do a little more searching. On the URD website I don't see any different size superchargers listed only performance packages that add on to the same head unit. I guess x-roller must get a different web page then I do when I search URD's site :adore:
