- Jan 14, 2007
- 1,513
This one is one of the aspects of the 1 GR-FE that truly sucks, and to those of us first gen owners, was a bloody nightmare to deal with for awhile before the answer was discovered.
Quite nicely, the solution is as easy as salt and pepper to a steak.
Simply weld in place an 18 inch resonator that is a straight through design, or a muffler with packing that is the equivalent volume, directly after the y-pipe to one pipe flange. This should eliminate your rasp, even with DTLT's. I mean, it did for me and i wasn't even running a muffler. :laugh:
The system I had when I first discovered this was an Intake, DTLT's, URD Y-pipe, magnaflow catback with an Aero-turbine muffler in place of the magnaflow muffler. This setup was so ****ing loud, and at low low rpms the low frequency tone was so loud it would literally rumble cars next to me like a pair of 13 W7's. Only problem was with 1/4 throttle or more, between 2.5k-3.5k rpms, there was this total fart can filled with pop rocks sound - like a chainsaw shitting tiny pebbles.
Keep in mind that the aero turbine is about as wide open as you can get, no packing or anything, just an air foil.:
http://www.youtube.com/watch?v=iDTTOa77efs
Meaning that the level of sound deadening was, well, borderline non-existant, So i was running straight pipes essentially.
Well, when I first went to the exhaust shop I had an 8 inch Aero-turbine resonator welded about a foot down wind of the y-pipe to one pipe flange. It helped, but the rasp was definitely still noticeable. About a month later I had that resonator taken out and replaced with an 18 inch magnaflow resonator, this one to be exact:
http://www.mandrelexhaustsystems.com/servlet/the-148/ADD-ON--dsh--RESONATOR/Detail
Most importantly, it was welded in an inch down wind of the y-pipe to one pipe flange, not a foot, not two feet, one inch. Fired her up, took off, ZERO rasp, not even a hint!
I suspect it has to do with the acoustics of the 1 GR-FE combustion characteristics along with the exhaust design. Some thing about the two to one point creates a harsh acoustical wave form resonance at those specific rpms under greater throttle position.
Good luck fixing your crappy sounding vehicles.
