5H4D0WD347H
- Apr 24, 2007
- 10,450
Anyone going to try one of the NOS/NX intercooler spray kits? I hear they are good for a nice 20 - 50 HP!
SignUp Now!Doesnt a MUCH colder intake charge reduce the chance of detonation? I wouldn't use nitrous id use Co2.
Well, IMO, I kind of turn away from water injection, just for the fact you're injecting water with fuel into the engine. Lowers octane. From what I understand.
i dont see how its getting sucked into the intake through the intercooler ?I would look into the water injection kits far before an intercooler sprayer. I have heard plenty of stories about problems, spraying nitrous onto your intercooler and then it getting sucked into your intake? Kinda makes sense that on some setups it makes 30-50hp, then again it also makes sense that people have blown motors running lean. On the other side of things if you want to run water injection or methanol injection you can still chill your intake charge and run a good bit more timing before seeing knock.
or do you mean as it passes through it then gets sucked in the intake :dontknow: cause air actually doesnt inter the intercooler it flows through it
yeah i kinda figured thats what he was talking about just wasnt sure .Some Intakes may be close enough to pick up some nitrous lingering in the air while the intercooler is being sprayed. I believe Co2 is much cheaper and if it happens to be sucked up it will do anything but gain you power/detonate.
It's water/Methanol injection, from my understanding the methanol helps to raise octane level..
I hope so... or you guys would be screwed! :ahhhhh:
