sdxrunner619
- Jan 20, 2010
- 3,836
- 7
So as some of you may know, I, for the most part appose the rear brake conversion, as I screws up the front to rear brake distribution. I finnaly installed a proporting valve. It is adjustable from 0-57% maximum line pressure reduction. With it maxed out, full 57% reduction my rear brakes STILL lock up before the fronts. I bled front and rear brakes, so that's Not the issue. I will say this, its Like 80% better then before. Its takes a significant amount of braking to get lock up. It made a huge improvement, over with out it, but its still not enough...
All of this testing, was done with my ABS and ebd fully disabled, with matching tires front and rear. In the days before my bbk and rear disk conversion, I used to race with my ABS disabled(personal preference, not saying im any faster), and when installed the rear disk conversion and bbk, my rear brakes would lock up under moderate braking.....
So my options as they stand now, is to swap out my front pads for something that bites harder. Front pads are whatever rotora includes with the 355 kit... Any one know if all the calipers on the 355 kit are the same? I.e, rotors 6piston caliper is the same from kit to kit?
Probably going to order some EBC yellow stuff, as I know those sobs bite hard as fawk. Rims will never be clean again..:laugh:
Any thoughts on this predicament?
