they will be insanely loud. If you already have the catback and y-pipe and dont want to hack it up or change it you can always go JBA. Buts if performance is what your looking for and crappy sound is acceptable go DT. They will put out better numbers.
Unless of course, your willing to modify the catback and/or y-pipe to tone it down
Justin
SO TRUE! I am running the DT/C2c's and The URD Y and 3" Catback..It is horrible..The URD Components were designed to increase performance and sound using stock manifolds or the JBA Headers with stock cats welded on. I have first hand heard both setups...
JBA headers, stock cat, Y pipe, JBA EVOL exhaust = GOOD
Stock manifold + stock cat, Y pipe, URD 3" exhaust = GOOD
DT/C2C Headers, Y pipe, magnaflow 9 inch Cat, URD 3" exhaust = VERYBAD
Solutions:
Run two mufflers inline...NO CAT
Swaping URD's Absorbtion straight through 16" body muffler for a larger
baffled style muffler
Cut in resonators in each side of Y-pipe.
My solution: First Attempt... Replace muffler
DT/C2C Headers, Y pipe, magnaflow 9 inch Cat, URD 3" exhaust pipes, Custom Spintech Muffler Part# 5443 in 304ss = WILL SOON FIND OUT
If that fails to silence the noise..I will be removing the 9 inch cat and adding magnaflows 14 inch muffler..4 inch round or 4X9 oval..depending on the effectiveness of the spintech.
Testimonial:
I went to Jersey for the minimeet.. I believe the URD muffler got very tired after 500miles at 3k rpm 80mph..EGT's 900-1200 Constant for 8 hours or so.
It was loud when I left NH, due to the recent addition of the DT headers. When I got down to Jersey it was unbearable...
Riding in traffic yesterday it was
COMPLETELY Unacceptable! I cannot get to 2000 rpm or put any load on the engine..(no "stepping on it" no matter the RPM) with out SEVERE barking. I like volume for those of you who may think I'm overreacting, This setup makes an Ugly Ugly rasping sound...no one would ever say sounded good.
So base your muffler on the fact you'll have headers someday...If you are getting headers put them on first and then try to increase the exhaust flow and sound. Otherwise you will be UGLY loud. Hope this helps...-krill
PS. Neither products are at fault for the effect..They simply weren't design to be used in conjunction.
