How many people here have had their pressure plate get weak and fail on them? Mine has slowly been getting worse and worse over the past 8 months or so, but now it's completely done. I took the slave cylinder guard off and looked at it while a friend pressed the pedal in. THe slave cylinder goes full travel, the throw out bearing presses the release fingers in, but the large contact surface stays put. you can even see where the strap hooks that connect the contact surface to the opposite end of the release finger levers have bent to a level where they aren't doing anything anymore. it sucks that this happened at 62,000 miles. This is the second problem I have had with this truck (LSD not LS'ing after about 15K miles of hard driving kinda pisses me off, but I can get the eaton diff to fix that problem). I am buying another stock plate (113 bucks) because I HAVE to have this truck run immediately, but I don't like the idea of yanking the trans every 60K. Are there any alternatives besides centerforce?
