Show off your intakes
motoxx199
Just want to see what kind of intakes everybody's running
jecbearclaw
Nice setup! Notice any power increase?
I've been looking into changing my stock intake with an aftermarket one. Has anyone tried to use the hood scoop for a ram air system? Or have you had any luck with using the hood scoop with a box next to the wheel well, still using the air from over the wheel as well?
motoxx199
The power Gains are decent I did notice a little bit. It does use the air from the inner fender. The only complaint I have with it is it's a little too loud but that's probably because it has such a large diameter intake tube. I have searched for A functional hood scoop and found a couple things that people homemade but nothing bolts on.
hrspwr236
Volant makes a great intake and has an option for a scoop.
12trdtacoma
I have Urd Tcai on my 2012 tacoma
motoxx199
Nice definitely like the URD intake I think I'm going to change out my airaid for the URD.
Coupe
This is on the other end of the hose going to the grille.
on to the neXt
Just curious, does anyone have the template for the urd tcai. I hit a deer and now need to cut the hole and can't find mine
12trdtacoma
U should be able to get it pretty close by using some of the holes aready in the radiator support and trim to perfect fit almost all of it has to come out so the pipe doesnt hit and rub a hole into it
