Snow tires
redarkx
All right northern guys and gals. I'm from Arkansas and I hardly ever see snow down here, and if it does then the whole city shuts down. I'm fixing to move to a place that actually has a winter, Columbia, IL, and I was wondering how the XR will handle snow. Do I need snow tires? Are blizzacks a good investment? Should I just try to by a beater and park it in the garage during the snow? These are all questions I cant figure out. Any help is appreciated guys!
hiflyer
I ran blizzaks last year + 100lbs in the bed and it was pretty good :)
That said, you can't beat 4x4 for traction...
Dirty
blizzacks are pretty awesome. i had them on my 2wd dakota and it toughed through some serious powder. just dont forget to throw some weight in the back.
redarkx
True, but I don't know if I'll be able to by anything by winter. Moving up there January 1st. :(
justin13703
If you can get a beater. I bought a 97 Cherokee for like 500 dollars and it's a tank in the snow. That being said, if you try to drive the x in the snow with the stock potenzas, I have gotten stuck in a flat parking lot. With a dusting of snow. Either get snow tires and put weight in there or get a beater that way if someone else slides into you it's not the x.
darthyota
The best winter tires you can get are a Nokian hakkapeliitta 5 studded. Now that being said the x Is really good in the winter even with out wieght but like others have said you can not run the stock potenza or any other summer only tire as the rubber compounds arent ment for the cold
Canadian Girl
I run X-Ice by Michelin... and go out and buy this
http://www.shurtrax.com/
Worth its $$$ in gold.... saved me a few dozen times... plus it doesn't becoming a projectile god forbid you are in an accident
MplsX
I love my shurtrax! I keep it in the bed most of the time since it makes the ride much smoother. Lowers the rear a bit also. Highly recommended!
dcaff05XR
The Blizzaks will be fine. I live in jersey. If u wanna throw some weight u can. I got cheap 16in. sport edition wheels with Blizzaks mounted and balanced and shipped for $800. The truck is fun and controlable. tirerack.com
butters607
um i would get them studded studded snows are absolutely awesome
