This is not the case. I know members have had the TRD SC flash done W/O the gas pedal recall. Talk to the dealer beforehand if you do get the reflash to make sure they get you the correct file.
Every master tech I talked to, told me you cant request the trd recall file, with out the ecu being reflashed for the gas pedal recall. It wont let you update it. Hard to explain, you have to see the tis/techstream software, to understand what I mean by "wont let you". Here's the easiest way of putting it. Let call the reflash file, vs. 1.5, and the trd reflash file, version 1.5.1....
You can't jump from version 1.0(unflashed), to trd 1.5.1, with out 1.5(recall reflash). The computer(techstream), wont let you. Now, there was a "butter" zone, where for a few months, before the updated trd reflash came out, where, if you haven't had the gas pedal recall done, You could still request the trd reflash, but the old version that doesn't support the 90l recall. (Gas pedal refalsh)
You might recall, in late 2010, some members complaining about not being able to get the trd reflash w/ the gas pedal recall. this was caused by the issues with the calibration file on trd reflash, being "older", then the 90l recall. Its kinda like trying to update your computer, from version 2.0, to version 1.9.
Unless some techs have the old (pre 90l recall) calibration files, saves on a separate hardrive or something, there is no way on 05-08, to skip the 90l recall, and get trd reflash, that I am aware of. If any techs on here, know of a loop hole, please, post it so other members know how to avoid it!!!!:rockon:
Here's the catch...on 09-12, you can request the trd file, w/o the gas pedal reflash recall...the ecus are different on the 09+...this is just what I was told, I have not confirmed it.
