SignUp Now!Im thinking about getting the URD S/C on my 07 x how reliable is it, does anyone have any bad stories about it or anything, is it worth losing the warranty, and what will it put my 0-60 time at?
Yeah... it seems any of the problems that HAVE occured where mostly due to user errors.. If i had the cash i would have one on my truck :top:
I believe Spyder is putting down the most power with it so far :rock:
i've had mine on for 10,xxx miles with no issues.
any issues you may have call up the boys at URD they have always taken very good care of me in the customer service dept. :rock: :top:
i've done a little tuning on the fuel map, but never played with the timing or taken it to the dyno.
i have it mid to high 10's mostly. there are a couple spots that I hit low 10's. I have a little more tuning to do, but it is getting closer to where i want it.
I've only put a few thousand miles on mine so far but it's good as gold! If you have the money & hate that wimpy A$$ stock motor, then it's a "must do".
I've never regreted it for a second...unless you count wishing for even MORE POWER!
Are you running the URD stock config?
I believe he is..
Correcto, Senor Spyder.....at least for now!!!
ill be running the 80 mm pulley when i get time to install it.
How long you been running the S/C?
your gonna love the difference from the 85mm to the 80mm :rock:
Where did you guys put gauges by the way? I have the LC1 XD16 combo I need to put in.
